**URGENT STUCK IN ALASKA** CDL Issue
Old Aug 19, 2019 | 07:55 PM
  #31
redwhitekat's Avatar
Originally Posted by Richard Gallant
@redwhitekat I had him try that no luck, it is a new transfer case so I am thinking that the interlock is not releasing Which may be that little pin not being far enough in to release. I wish there was a clear description on how that thing works.
That’s to bad it sucks that’s he’s stuck and that piece is not easy to get to
at least he can move slowly and hopefully find a shop that knows something about this
is he putting it in neutral ??
I literarily just took solenoid out put it on a vise and cut the pin off with my grinder than I reinstalled it like it was. Didn’t hook any wires back up as that pin on the solenoid is just to prevent you from moving the high low lever without it being In neutral
Old Aug 19, 2019 | 08:00 PM
  #32
Richard Gallant's Avatar
@redwhitekat thanks for all the suggestions this is a head scratcher for sure. He is going to try and release the cable in case something is binding further up
Old Aug 20, 2019 | 01:27 AM
  #33
acg's Avatar
acg
Richard,
You are a life saver with communicating with me via text this afternoon! Finally got into a campsite with internet access. Good news is I was able to disconnect the cable linkage and move the triangle pic into the inside ear section for the low side. However, I sill can't get it to move to the other inside ear section of the high side when doing a test drive. No more daylight left.
Will try again tomorrow. Looking on the optimistic side, we (including my 15 year old son) are becoming more familiar with the 2004 diff lock
Good nite!
Old Aug 20, 2019 | 01:39 AM
  #34
acg's Avatar
acg
Got these pics off Ebay of the 2004 linkage. Keeping for reference....
Old Aug 20, 2019 | 01:40 AM
  #35
acg's Avatar
acg
Old Aug 20, 2019 | 10:15 AM
  #36
@acg that helps a lot so the problem is on the other end where the cable meets the arm that actually moves the internals. That far arm on the cable should be on the left side near the front of the transfer case. But it is very hard to get at you need to go up between the transfer case and transmission pan right by the Y in the exhaust. if you can the get cable attached you would be able to see if it moves at all
Old Aug 20, 2019 | 12:06 PM
  #37
Jason Feuerstein's Avatar
Honestly, at this stage I would take the center console out and go in from the top. The removal process isn't that bad, and as a final resort you can disconnect the cable from the shifter and actuate it manually.
Old Aug 20, 2019 | 12:53 PM
  #38
@Jason Feuerstein it may come to that but not something you want to do between Skagway and Whitehorse, currently the Disco is mobile if only slowly. The plan is to drive the 100 or so miles to Whitehorse in low that will take about 6 or 7 hours, once there he can get a shop to look at it.
Old Aug 20, 2019 | 01:49 PM
  #39
mollusc's Avatar
i once removed the central console in a carpark during a snowstorm because the shifter collar had come loose so my transfer case was stuck in neutral. it's not a hugely difficult thing to do.
remember that the 2004 lever has been retrofit to this truck, so the central console panel may be even simpler to get out than the original riveted one.
Old Aug 20, 2019 | 01:58 PM
  #40
@mollusc his concern going that far down in Skagway is getting stuck there, in Whitehorse he can leave the Disco and fly home if required or get parts
