*help* Intermittent no start
Old Jan 1, 2016 | 04:12 PM
PanamaDisco's Avatar
Default *help* Intermittent no start
The other day at work when I went to leave at the end of the day my 2001 disco 2 would turn over fine but would never fire off. The next day it started fine. It has happened to more times since then and yesterday after having problems starting I drove about a mile and it shut of. After it shut off I notice the D for drive was flashing and the green M and S after I turned the key to the off position waited a few minutes it started back up. No lights on. My first guess is a fuel pump but I figured I would ask the experts on here first. Thanks in advance.
Old Jan 1, 2016 | 05:29 PM
cappedup's Avatar
Earth (ground) fault. Im working through one at the moment. Check battery terminals and all ground points.
Old Jan 1, 2016 | 08:46 PM
After reading another thread I am thinking it might be the crank positioning sensor. Any thoughts?
Old Jan 1, 2016 | 11:57 PM
RoverDoc88's Avatar
check for oil leaking from the valve covers on to the crank position sensor if they are you can experiance this problem
Old Jan 2, 2016 | 07:10 AM
drowssap's Avatar
sound like ckps you can check it with a obd2 scanner, check the rpm while cranking 0 rpms = ckps.
Old Jan 2, 2016 | 02:40 PM
RSDEVIL's Avatar
Exactly what Drowss said. No signal = cps. At least it did on my intermittent no start. Changed it out and it has been fine for over a month now. I made a thread and he also linked me to another guy who cut a access door as I wound up doing the same. Thanks again...!!!
https://landroverforums.com/forum/di...ttently-76865/
Old Jan 4, 2016 | 06:57 PM
Well I just finished replacing the CPS. Took me about a hour and a half if I could of gotten to the plug a little easy would of been under a hour. It had obviously been replaced before because the plug that the new sensor had to snap into was not in its clip. I had to use a bunch I mean a bunch of lube to get my four arm to slide past the exhaust but I eventually got it all put back together. Crossing my fingers that the problem is fixed.
THANKS FOR EVERYONE'S HELP!!
rockyblue123
May 9, 2012 03:58 PM
bobm
Mar 5, 2012 07:13 PM
Roverfix97
Mar 26, 2010 04:41 AM
jonman
Aug 14, 2008 10:50 AM
DiscoGal
Oct 17, 2006 03:36 PM
