01 disco P1300, P0303, P0302, P301
Old Feb 8, 2017 | 07:20 AM
LRD2rangel's Avatar
resources did my gapping for 1,2 and 3 to .042. runs a bit better. the idle is still rough. SMS is blinking. could it be the injectors?
Old Feb 8, 2017 | 07:22 AM
LR03NJ's Avatar
SMS Blinking? Do not drive. Catalytic will be compromised. Recheck codes.
Old Feb 8, 2017 | 07:37 AM
LRD2rangel's Avatar
Service Engine light. rgr so no driving till issue is fixed. will recheck codes when I get a chance.
Old Feb 8, 2017 | 08:11 AM
LR03NJ's Avatar
To a point, misfires could also be injectors. I am not sure if clogged injectors will present a code unless its injector circuit related that caused its malfunction. Some codes like P0201, P0202, P0203, P0204, P0205, P0206, P0207, and P0208. I think the way to test them is to check them individually.
Old Feb 8, 2017 | 12:38 PM
LRD2rangel's Avatar
is checking the injector a hard task? I am stuck doing most of my repair work at night.
Old Feb 8, 2017 | 01:24 PM
LR03NJ's Avatar
If your up to the task, then its not too difficult. Couple of bolts but a lot of patience. Its hard to see from the engine. You'll be able to see just the front ones. Its a job almost near doing a head gasket, almost. This only if you have to do it. Its just because, once you get in there, you might end up replacing a bunch of stuff. Something like, after putting things back you might have wished you change the head gasket. Its just roughly six bolts to get down there. Give and take, a month of work and waiting for parts. Better have all the parts. Injectors cost about -$100 remanufactured for 8pcs. Got those when I replaced my head gasket.
Old Feb 8, 2017 | 01:27 PM
LR03NJ's Avatar
This is how far you have to go.
Old Feb 8, 2017 | 02:50 PM
LRD2rangel's Avatar
is the method or procedure to clean the injectors? I will doing the HG and injectors in one go.
Old Feb 8, 2017 | 03:02 PM
LR03NJ's Avatar
Here is where I got my injectors if you decide to purchase.
*3 Year Warranty* 4.0L 4.6L V8 Replacements GENUINE BOSCH Fuel Injector Set (8) | eBay
Here is a link how to clean them.
Well, if you decide to take a plunge, there were about 6 guys in this forum who did the head gasket since november. I'm sure there are plenty here who can help in case you get stuck. Cheers!
Old Feb 8, 2017 | 06:17 PM
Luckyjayb's Avatar
This is the guy I used and he was jam up and they work great. http://Look at this on eBay: https://www.ebay.com/itm/121949854605 Bosch 0280155787 Fuel Injectors 99-04 Land Rover 4.0L 4.6L Discovery II Set of 8
