01 disco P1300, P0303, P0302, P301
Old Feb 8, 2017 | 06:18 PM
  #21
Luckyjayb's Avatar
https://www.ebay.com/itm/121949854605
Old Feb 8, 2017 | 06:20 PM
  #22
Luckyjayb's Avatar
Originally Posted by Luckyjayb
That's the correct link now. He can either clean em for you or send you a matched set and give you $30 for your core. Tell him rrjasonbrock sent ya and he should knock a little off
Old Feb 10, 2017 | 03:46 PM
  #23
LRD2rangel's Avatar
No new news here. working on getting a HG replacement kit and stuff to clean the injectors. thinking of building a bracket to relocate the coil pack. ( might have to reroute wires. updates to come when I can.
Old Feb 10, 2017 | 04:10 PM
  #24
LR03NJ's Avatar
Great, get all the parts you need so to cut wait time when ordering parts.Also, if you don't have it yet, get the fan wrench to remove the clutch fan. Check out the relocation I did.
https://landroverforums.com/forum/di...t-82610/page3/
Old Feb 16, 2017 | 10:56 AM
  #25
LRD2rangel's Avatar
Saw the relocation, looks awesome, just ordered a ultrasonic cleaner and injector clear, local salvage yard has 2 discos, gonna pull injectors from them. I will clean those and swap em for mine. will post pics of process
Old Feb 16, 2017 | 02:31 PM
  #26
LR03NJ's Avatar
nice to see that happen.
Old Feb 17, 2017 | 09:14 AM
  #27
LRD2rangel's Avatar
using Lucas cleaner in the ultrasonic, thinking it's too thick. is there a better cleaner that is less viscous?
getting the heads off of one of the salvaged discos, I am going to clean those and place the HG kit on those then swap it for mine. this should keep down time to a minimum.
Old Feb 17, 2017 | 11:14 AM
  #28
LR03NJ's Avatar
I never tried cleaning them but as the video showed in the beginning, he used Carb cleaner.
Old Feb 24, 2017 | 08:41 AM
  #29
LRD2rangel's Avatar
So I rechecked my cables yesterday, no longer has 3 misfires, just 1
getting P0303 and P0203 now.
P0203 is injector circuit open, not sure what this means
Old Feb 24, 2017 | 09:29 AM
  #30
LR03NJ's Avatar
Did you clean the injectors? Or you decided to get a remanufactured ones?
The reason for those codes are these.
Injector failing or failed in cylinder 3
Open or short found in the wiring harness
Electrical connection that is poor
If you are getting misfire on cylinder 3, it could definitely be the injector 3.
