01 discovery oil light on after timing cover gasket change
01 discovery with 120,000 miles.
So I just changed the timing cover gasket, waterpump, crank seal, oil pan gasket. After 30 miles on it, hot and at a idle I get the oil light on. Not flashing and no knocking. I did not change the timing chain or oil pump. Any ideas. What to do?
HELP ME!
HELP ME!
You may be experiencing a walked cam bearing. This happened to me and a few other people. I just finished repairing mine a couple of weeks ago. It is a major job, but is doable. Do a search for walked cam bearing to find out more information and how to diagnose it (you can see it from the bottom of the engine with your oil pan off).
No -- The light came on briefly at hot idle. That led me to replace the oil pump gears (which were cracked). After that repair, the oil pressure light still came on at hot idle -- which led me to dig deeper and then I found the walked cam bearing.
[QUOTE=lrjon;566021]
My mistake. I missed where he addressed you
I was referring to OP. Sorry guys!
