'01 SE7 Rear door leaking
Old Mar 21, 2008 | 07:13 PM
jhammerstrom's Avatar
Default '01 SE7 Rear door leaking
My rear door is leaking a fair amount at the top. If it rains hard or I wash it I get water coming in at the top of the door.
Is this a common problem? The seal looks OK and the door is shutting tight.
Old Mar 21, 2008 | 09:18 PM
Default RE: '01 SE7 Rear door leaking
Well the only way it will leak is if the seal has flatened out or the door needs to be adjusted for fit. For the most parts, they don't leak, even as big and heavy as they are.
Old Mar 21, 2008 | 11:42 PM
socalrover84's Avatar
yes most cases its out of adjustmen its probably too low.
Old Mar 22, 2008 | 09:51 AM
JEFIII's Avatar
Open the rear door all the way and just loosen the hinge bolts. Grab a helper and while you lift the open door up, have your helper tighten the bolts. Should seal perfectly.
rally1
Feb 22, 2022 06:22 AM
NWRover750
May 24, 2008 01:08 PM
ajh
Oct 4, 2006 02:21 AM
TwinCities
Jul 19, 2006 09:14 AM
pinba1173
Sep 15, 2005 04:19 PM
