02 Discovery II. Coolant issues.
Old Sep 25, 2012 | 02:20 PM
  #21
jfall's Avatar
Try my test.
Take the cap off on the warm engine.
If it does not toss out antifreeze, you are good.
And, if you don't have the gurgle you are good.
Since it seems you can bleed out all the air - then you have no HG issues.
Old Sep 28, 2012 | 12:52 AM
  #22
JasonjCook's Avatar
Originally Posted by jfall
If you have the waterfall sound from your heater core - when you start off from stop lights = then your system is not bleed correctly.
Would this cause over heating at long idles ... However I do also have water on passenger floor ..... Best case could be flush fluid and clogged ac nipple I guess but most likely wishful thinking (2000 disco 175k)
Old Sep 28, 2012 | 01:24 AM
  #23
lr2001silver's Avatar
Banned
Water on passenger floor is a issue with the heater matrix it self or the O rings that are on the heater matrix pipes. Small little .39cent rubber O ring, pain in the **** to get to kinda.
Old Sep 28, 2012 | 05:33 AM
  #24
drowssap's Avatar
i thought you said you preasure tested it for over an hour and it did not drop.
Old Sep 28, 2012 | 08:07 PM
  #25
aarongregor's Avatar
jfall I like you test idea. Makes perfect sense and its super simple.
Old Sep 29, 2012 | 12:45 AM
  #26
jfall's Avatar
Yeah.
My test is simple.
So simple that no one ever takes it seriously.
Worked for me.
When my head gaskets were bad - the Rover D2 spewed out antifreeze at a high idle.
When the head gaskets were replaced and the system bled - the antifreeze stayed in the cooling system and in the coolant tank even with the cap removed at a high idle.
20024point6
Mar 3, 2009 08:59 PM
20024point6
Mar 3, 2009 06:56 AM
bearcatfans
Dec 12, 2007 04:47 PM
karmannbee
Dec 23, 2006 10:07 AM
