02 Sensors (need help!)
Old Dec 18, 2018 | 11:46 PM
OgEric's Avatar
Unhappy 02 Sensors (need help!)
I had a check engine light, so i plugged in my OBD2 reader and it said "02 Sensor Circuit no activity bank 2 sensor 1". It also notified me that I had 2 misfires in cylinders 4,8. So thinking that the O2 sensor was the main culprit, I ordered some Bosch 02 Sensors. Couple days later I install the new sensor and everything seemed fine, until 10 min later the service light illuminated. So I plugged in my obd2 reader and it said "02 sensor circuit Bank 1 Sensor 1" P1030. I was wondering if you had to replace the o2 sensors in pairs? (I ordered another one already)
Old Dec 19, 2018 | 12:40 PM
LR03NJ's Avatar
Its ideal to replace them both but not necessary.
Old Dec 19, 2018 | 02:02 PM
mollusc's Avatar
Bosch O2 sensors have also been reported to have a high failure rate out of the box.
Old Dec 19, 2018 | 02:23 PM
Friday Night Disco's Avatar
Swap the driver and passenger side and see if the code follows before buying more O2s
Old Dec 19, 2018 | 04:11 PM
mln01's Avatar
Or reinstall the original 1/1 sensor.
Old Dec 19, 2018 | 05:38 PM
matt3502's Avatar
I went thru 3 pair of Bosch sensors before I gave up and went with Walker from A British.
Old Dec 21, 2018 | 01:04 AM
OgEric's Avatar
I am happy to inform you guys that the new sensor has fixed the problem! There is no more service light. However I found the problem was that the sensor was filled with oil. My disco sadly has an oil leak (2003 Land Rover Disco 2 HSE with 104,000 miles)
Old Dec 21, 2018 | 07:39 AM
Extinct's Avatar
You likely have a plugged valve cover baffle, remove and replace with Pcv mod and your oil leak will go away
Old Dec 21, 2018 | 02:44 PM
OgEric's Avatar
What exactly is that? And do you know how hard that job will be.
Old Dec 21, 2018 | 02:55 PM
OgEric's Avatar
Also what Is a PCV mod?
