03 disco cdl
Old Jul 25, 2019 | 08:43 PM
redwhitekat's Avatar
Originally Posted by Best4x4
To properly adjust it manually place the Transmission in park, then have your shifter in Park. Pull it snug by hand and let it go back 1-2mm then tighten the 13mm nut and go from there. A small adjustment is usually all that is needed. I've worked on em in all sorts of conditions. Shifter in D but trans really in 3rd or worse. Park & manually set Park at the trans should work every time.
That is what I did
Old Jul 26, 2019 | 03:54 PM
Ok got it all back seems to be fine only thing I didn’t do was hook up the wiring for the locked position
I can feel the low and high gears but can’t really tell when I lock the diff
I swear on my previous 04 you feel a huge difference when my cdl was locked vs unlocked
this one if I lock it I can’t really tell by driving it if it’s locked
Old Jul 26, 2019 | 07:54 PM
mollusc's Avatar
are you testing it on a high-traction or a low-traction surface?
because you shouldn't be driving it far on the former when it's locked.
Old Jul 26, 2019 | 08:18 PM
The Deputy's Avatar
Does your CDL light illuminate on cluster? Red X-wing fighter type symbol. Try driving the vehicle over some difficult terrain without CDL, until it won't continue...then engage CDL and see if it makes a difference...it should.
Brian.
Old Jul 26, 2019 | 10:33 PM
Brian.
No no light because I’ll have to find the wires and connected to the switch on the transfer box.
I did lift up one wheel in neutral it spun freely than I engaged the cdl and it no longer spun so u guess it’s locked.
Old Jul 27, 2019 | 11:55 AM
Brian.
I wish I had this terrain but we are in the flat lands here in Ontario not much around me unless I go on private property which I’m not
Old Jul 28, 2019 | 02:53 PM
Things I noticed while under there. 2 drains on either side one dumps on top of drive shaft other dumps on top of xyz switch, I stuck a hose up there to divert the drain away from xyz switch.
Question about the cdl, will I get any error codes while off-roading now that I put in the cdl ???
Old Jul 28, 2019 | 03:08 PM
mollusc's Avatar
you shouldn't get any codes, especially if you do any of the workarounds like cutting a wire or getting a later model slabs unit.
halbertse
Apr 2, 2015 08:36 PM
DiscoFever88
Jan 10, 2015 10:21 AM
bballjames
Oct 26, 2012 05:16 PM
Kalel
Jan 18, 2012 12:37 AM
big cheif
Jul 1, 2011 07:01 AM
