03 Disco Cylinder 4 misfire
Old Jul 19, 2010 | 11:30 AM
tflhund's Avatar
8th Gear
Default 03 Disco Cylinder 4 misfire
Newbie here...please help.
Just bought a dealer maintained 03 disco with 70K.
This morning, no extreme weather, got a p0304 + p0455 fault. SES light also came on. Called the dealership and the 60K service had been performed that included new plugs but not wires. Had the emission test done Saturday so I checked the gas cap and it was not secured. I tightened it and the SES light went of and seems to be driving fine. No cheap gas, no significant leaks or anything of the sort.
Q: Could the misfire and gas cap incident be related since the RAVE manual lists the P0304 fault as 'Injector 4 excess emissions/catalyst damaging level of misfire' and the gas cap is part of emissions control?
Your input is greatly appreciated.
P.S. If the wire(s) are bad, can a fairly technically inclined person do the job?
Thanks,
///M
Old Jul 19, 2010 | 12:48 PM
A loose/bad/missing gas cap will not throw a mis fire code, it will throw a EVAP leak code.
Yes plug wires can be done buy a Shadetree Mechanic.
Old Jul 19, 2010 | 01:05 PM
tflhund's Avatar
8th Gear
So it's the wires I assume since the plugs were done only 10K ago?
Thanks for the help.
///M
Old Jul 19, 2010 | 01:19 PM
lipadj46's Avatar
Thanks,
///M
Yes, in theory if you can unplug and plug in wires to a connector then you can change your own wires. It takes a little patience to do it with out taking off the upper IM.
Old Jul 19, 2010 | 01:22 PM
tflhund's Avatar
8th Gear
Thanks.
I found the Deepbluewater post with pics so I'll give it a go.
Big-Rob
Jan 29, 2017 01:09 PM
scarrell
Nov 16, 2012 06:04 PM
FLDISCO
Nov 18, 2011 07:53 AM
Huckleberry77
Jul 16, 2010 01:20 PM
RoverLover21
Oct 22, 2009 06:29 PM
