03' Disco head light condensation! help!
Old May 17, 2008 | 11:49 AM
snowdude's Avatar
Default 03' Disco head light condensation! help!
I recently bought a 03 disco about 2 mounths ago, after the temperature started warming up and more humidty started, the right (passenger) side head light started to condesate. the rover is in mint condidtion and everything looks perfect. any soulutions instead of a $200 used replacement? i have pictures ill post if you need.
Old May 17, 2008 | 12:10 PM
Default RE: 03' Disco head light condensation! help!
You need new seals.
I have done this on a Ford van, I took a very small drill bit and drilled three holes in the lens, two on top (one in each corner), and one on the bottom in the middle.
The condensation will evaporate out of the holes.
But the corect fix is a new gasket that seals the water out of the lens. Also check your bulb where it goes into the back of the lens, if it isint seated correctly it can let water in.
Old May 17, 2008 | 12:14 PM
snowdude's Avatar
ok ill go see if its no seated, this should be fun! lol
Old May 17, 2008 | 01:01 PM
meltdowndave's Avatar
I had the same problem.
I found one of the light connections to be just a bit loose. Once it appeared as though I didn't have a serious problem, I removed said bulb and applied a hairdryer to the front. The condensation heated up the water and it escaped through the light socket.
Be sure not to get it too hot, though. Otherwise you might scorch the plastic. Move it around a bit and stop periodically to let it cool off.
Old May 17, 2008 | 01:28 PM
shagybruce's Avatar
ditto on the hairdryer fix. i had the same thing did the hairdryer deal then made sure all the sealing caps for the bulbswere tight then applied a thin bead of silicone sealant around the inside edge of the lens where it meets the housing. no more condensation
Old May 17, 2008 | 04:44 PM
elrocha69's Avatar
Every good mechanic needs a hair dryer lol. I have removed decals, did window tint, dried headlights like you said, and oh yeah they're great for keeping a fire going on the bbq grill when you're too lazy or had a few too many to go to the store for more charcoal. But yeah, take the bulb out and use the hair dryer.
Old May 17, 2008 | 06:17 PM
Note to self, a bald man needs a hairdryer.
Old May 17, 2008 | 07:39 PM
elrocha69's Avatar
I'm bald , by choice that is.
[IMG]local://upfiles/8876/1E2504485D5A4CCBAF30F9026B356C8E.jpg[/IMG]
Old May 17, 2008 | 07:43 PM
I'm not by choice, but I love it. Haircuts are only $5, I have to wear a hat whenever I am outside though. If I forget my wife reminds me, and let me tell you, Hell hath no fury as that of a redheaded woman.
Old May 18, 2008 | 11:06 AM
elrocha69's Avatar
Trust me I know, My Mom is red headed!
yvanjerome
Mar 19, 2010 01:53 PM
tsuami1
Jul 15, 2009 02:28 AM
thorogood32
Jun 26, 2007 09:13 PM
xadamx
Jun 12, 2007 10:01 PM
mcbenavidez
Dec 7, 2005 06:53 PM
