03 disco seat replacement
Old May 29, 2013 | 10:51 AM
jna97's Avatar
Default 03 disco seat replacement
my drivers side seat leather is shot. i have an opportunity to buy a passenger seat in mint condition. my question is: can i use the upper cusion part of a passenger seat and bolt it to my drivers seat bottom mount?
thanks in advance.
Old May 29, 2013 | 03:56 PM
The upper covers have holes for the arm rest, they won't interchange.
Old May 29, 2013 | 04:41 PM
04duxlr's Avatar
If your lower seat is wiped out, then you can likely swap out the lower cushion and reuse your driver's seat back. The cushions are the same for either side. Check out RAVE for images and directions for disassembly. RAVE even shows you how to remove and replace the covers if you want to give it a try.
Grover11
Dec 26, 2014 04:59 AM
dierks
Dec 11, 2013 11:34 AM
keoni004
Nov 9, 2012 01:10 PM
jfall
Jul 23, 2012 04:32 PM
Nonce
Aug 4, 2004 03:26 AM
