03 disco stalling oil & battery light on. help!
Old May 11, 2009 | 11:15 PM
DISCOVERY182's Avatar
6th Gear
Default 03 disco stalling oil & battery light on. help!
Hi, ok so about a week ago my car started making a continuous noise, not loud but noticeable. it sounded like the belt or a pump but i'm not an expert so i don't know what it was or is. ok i'm driving home last night and it started to get really rough while driving then as i was coming to a stop my car stalled so i stopped it. turned it back on and continued to drive, as it started to slow down again it would make a quick high pitched squeek then stall again. so I pulled over, put some oil in it, ran it for a few minutes, it made some cracking and rattling noises , and tried to drive again, but same thing. The oil light and battery and check engine light are all on. I got a tow across the street from my house. later last night I turned the car on , it struggled and the lights flickered but it did turn on and put it in my drive way, it was no longer making any noise and sounded normal. so whats wrong with my bi polar car? please help
Old May 11, 2009 | 11:34 PM
skyguy's Avatar
not sure but the 03's have an issue with the oil pump. Be careful if you run it with a bad pump the engine could cease and then the engine is junk.
Old May 11, 2009 | 11:45 PM
6th Gear
what would the turning off indicate?
Old May 12, 2009 | 08:48 AM
I would suggest you send me your tele number ASAP and do not do anything to try and start it till we talk. as an 03, you may be loosing your engine.
Old May 12, 2009 | 09:37 AM
okdiscoguy's Avatar
yeah, call Mike. 03's have an oil pump problem and what you are describing sounds like a failure. There is a VIN range that he can check. Have your VIN ready..
Old May 12, 2009 | 11:40 AM
leadfoot's Avatar
Default Put some oil in it?
Originally Posted by DISCOVERY182
............. as it started to slow down again it would make a quick high pitched squeek then stall again. so I pulled over, put some oil in it, ran it for a few minutes, it made some cracking and rattling noises , and tried to drive again, but same thing. ............
Of the whole description of the incident, what struck me was the fact that you added oil to it. You did not mention that it was low, how low was it? To me that is very interesting statement. By Now you probably talked to Mike, but please share what is going on.
nateandnikki
Jul 2, 2013 06:38 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
flavorking
Feb 10, 2008 12:33 PM
arrkerr
Dec 14, 2005 10:06 AM
