03 Discovery A/C not working
Well I tried adding freon and it would not take... So then i just jumped the terminals to battery and truck started cooling, low was cycling between 30-100 lets say... I was out of hands so didnt get super accurate differentials on high side but that was general area... So basically by bypassing plug it seemed to be working and cooling... But it never started taking freon so i stopped that... Anything else to look for before taking to ac shop?
I have a harbor freight almost across street btw
On your fliter/drier or just before entering the cabin is a low/high preasure switch for you a/c system, You should try jumping it there.
If you jump it there and the compressor kicks on the the system is probably low enough on charge to shut the compressor off to avoid damage.
The preasures that you are read on your guages are subject to all sort of ambien changes, such at OAT, air flow across the evaporated.
If you jump the preasure control and the compressor comes on, just bring it to someone and have them pull a vaccum and recharge the system.
... I also noticed the fan up front does not come on when pushing ac button on clamate control box inside as it used too... However fan does work normally when temps go above 204deg
Also i guess jumping relay since i kow its good would do nothing? Would it engage compressor?
Im looking at page 1208 on RAVE that has to do with troubleshooting sensors by holding the "auto" button while starting truck and then it would show a trouble code for sensors i think im understanding correctly....
Well.... After 3 or more weeks no a/c ilearned a very hard lesson.... Not sure what that was except... MAKE SURE THE ECON BUTTON IS OFF!!! Hahaha when looking to read codes on climate conol unit guess what i saw!!! ECON BUTTON WAS ON! =NO A/C! Lol pushed it and a/c working!!! Hahahaha oh well i at least learned how to use my fancy gauges!! Lol i added a can of freon... Low side was sitting at 23 so i bumped it up to 32.. Outside air around 75F ... High side sround 165! It was NICEN COLD INSIDE! Hahaha can you beleive! Lol i rememebr my GF was fiddling with my a/c saying her side was too cold and she hit the econ i bet! Lol GGGRRRR!! And its been unseasonably warm n steamy! Lol
