03' front end problems
so my 03 D2 is a real headache to maintain. this is the deal. driving down the road starting at about 20mph my vehicle starts making a vibration that feels similar to when you drive on the rumble strip on the side of the interstate. alltho its not nearly as intense. it rumbles up to about 40 mphs then goes away and comes back about 60 and goes away about 70. it whins the most when you start coasting, it gets more intense. now. it was like this for a couple of weeks. then one day it completely stopped. it has been fine for the past month and a half. now i have a really loud squeaking sound that happens only when there is any amount of power going to the wheels. the rate of the squeek changes with the rate of the vehicle. now. the squeaks are not 1:1 with the wheels. more like 4:1 squeek to wheel ratio... any ideas? u joints maybe ?
on
David, where did you go?????????????
I would stop driving that truck this morning and pay attention to your replies, your front drive shaft is most likely about to gernade it self and your tranny.
If you have not rebuilt or replaced the front drive shaft, if it only has one grease fitting and you just plain don't lube the joints, then that is what is wrong.
hey fellas thanks for all your help. i pulled the drive shafts this morning and sure enough the needles bearings on the 2 UJ's next to the transfer case were completely shot. i went and bought new UJ's and rebuilt all the ends and that big cluster on the front shaft. that solved the problem
AlexERAsDisco
12-16-2006 03:18 PM
