04 CDL lever not moving
Old Feb 21, 2011 | 01:11 PM
mdf27's Avatar
Default 04 CDL lever not moving
I just bought another 04. The CDL on a 04 has a cable correct? On my D1 the linkage was frozen from previous owner not using so I took linkage apart and cleaned and lube everything and I was good to go. I have not had the time yet to pull anything apart on the 04 just wanted to see what you guys thought. Lever will not come out of H and will not move side to side either.
Mark
Old Feb 21, 2011 | 01:13 PM
NiteTrain's Avatar
yep, it should be a cable
Old Feb 21, 2011 | 01:18 PM
mdf27's Avatar
on my D1 the part that was frozen was the shifter part not the linkage and I asume the D2 may be frozen is the same place from no use.
Mark
Old Feb 21, 2011 | 03:42 PM
jafir's Avatar
I think it's just broken. Completely. Beyond repair. Just remove it and the two cables, and send them to me, and I'll recycle them for you.
Old Feb 21, 2011 | 06:08 PM
mdf27's Avatar
Smile
with my D1 the dealer said I needed a transfer case and I took it apart and it worked like new.
Mark
Old Feb 21, 2011 | 08:42 PM
The '04 uses cables to move the t-case shifter, so you either need to try and get lube inside the cables or replace them.
Old Feb 22, 2011 | 06:45 AM
mdf27's Avatar
I may just order new cables before I take it apart if they are not $2000. could the lever be frozen?
Old Feb 22, 2011 | 07:08 AM
Bundu's Avatar
Banned
They are about $200 for each cable.
Old Feb 22, 2011 | 10:28 AM
NiteTrain's Avatar
the dealership quoted me over $400 for one
Old Feb 22, 2011 | 04:48 PM
mdf27's Avatar
Where is a good place to buy them? I looked at roverparts.com but did not find them. Ill try to free them first if they are $200 ea
