04 disco 2 started, warmed up for 20 mins then died while driving, wont start now
Old 12-05-2019, 05:23 PM
Ohiorover's Avatar
3rd Gear
Default 04 disco 2 started, warmed up for 20 mins then died while driving, wont start now
Hey guys,
Have had this disco2 for almost a year. I started it no problem, it warmed up for 20 mins. No issues. Drove for about 5 mins. Pulling off from a stop it stuttered and shut off. Turns over, even almost starts but doesnt. Alot of posts on here point to CPS. Is this where I should start?
Also hazards did not turn on during this.
Old 12-05-2019, 07:51 PM
Extinct's Avatar
Received 1,460 Likes on 1,036 Posts
Let it cool off, if it start, yes it is CPS. Could be fuel pump, easy to test. Could be a fuse, but CPS is the most common.
Ohiorover (12-05-2019)
Old 12-06-2019, 02:44 AM
JUKE179r's Avatar
If it is a faulty CPS get a Bosch #ERR-735 or NAPA's Echlin #CSS9280 (supposedly a Bosch brand in NAPA box).
Ohiorover (12-06-2019)
Old 12-06-2019, 05:03 AM
SundayFunday's Avatar
For whatever it’s worth- I’ve had longevity problems with sourcing the CPS thru Napa -
genuine Bosch from a rover source made a difference for me.
Old 12-06-2019, 05:41 AM
JUKE179r's Avatar
Good to know.
Old 12-06-2019, 06:26 AM
Lots of cps posts popping up lately
something to do with this time of year ?
Old 12-06-2019, 09:53 AM
Received 1,146 Likes on 792 Posts
@redwhitekat the universe looked down and said it is too quiet in rover land best have something cheap but painful to replace fail
JUKE179r (12-10-2019)
Old 12-06-2019, 10:20 AM
never a dull moment in rover disco land.
Old 12-10-2019, 11:05 AM
Ohiorover's Avatar
3rd Gear
Found a link on here for the crank sensor from Amazon, was a Bosch part. Tried it no change. It will crank but no start. Wanted to check fuel pump next. Can I test it from the port hole in the back or will I need to rent a gauge tester and check on the rail somewhere? Thanks fellas
Old 12-10-2019, 11:20 AM
Sixpack577's Avatar
There is a Schrader valve on the back of the fuel rail, driver's side.
Ohiorover (12-10-2019)
Quick Reply: 04 disco 2 started, warmed up for 20 mins then died while driving, wont start now
