04 Discovery II goes into limp mode when shifting into neutral
Old Dec 26, 2022 | 06:32 PM
betzdII's Avatar
Default 04 Discovery II goes into limp mode when shifting into neutral
After fixing the problem with my XYZ switch, my discovery was running great 300-400 miles later the m & s green lights start flashing and goes into limp mode when I switch into neutral (transmission). I can here clicking around the transfer case shifter. Would a bad TC solenoid cause this to happen if its faulty. Can I unplug from back of the TC to see if its goes away.??
Thanks, Bub
Old Dec 26, 2022 | 06:42 PM
Harvlr's Avatar
I don’t know if this is your issue but I know that low battery and/or alternator voltage will cause a lot of transmission faults. It doesn’t need to be very low either.
Old Dec 26, 2022 | 06:56 PM
betzdII's Avatar
Voltage is good 14.3 when under load and at idle. It won't let me shift past N before it starts clicking. And only will do it when the Disco is running. Thanks for replying.
Bub
Old Dec 27, 2022 | 11:11 AM
ahab's Avatar
The TC case solenoid only prohibits you from move the lever from High to Low (or back), and would be unlikely to cause this problem if it were faulty. You simply won't be able to move the lever. My first through would XYZ switch, despite having just replaced it. Have you gone back under to verify the connections are good, both electrical and mechanical?
Old Dec 27, 2022 | 01:06 PM
betzdII's Avatar
Yes I actually took it apart again to make sure everything looked good inside. reinstalled it same thing.
Old Dec 27, 2022 | 02:49 PM
zski128's Avatar
There is a solenoid in the transmission shifter to keep you in park with the key out. Is that maybe the clicking you are hearing ? The M&S lights flash for over a dozen different reasons. The primary cause is low battery voltage when starting the vehicle. I just had this issue even though the battery tested ok it was borderline enough to drop voltage enough during cranking to make the M&S lights go off. I got a new group 27 battery and it’s fixed.
I would get the transmission codes read first to see what the code is. I believe autozone (depending on the scanner they have) can read the trans codes.
Old Dec 27, 2022 | 03:46 PM
betzdII's Avatar
I have the console out of the car so I could check grounds. I can feel the clicking right in front of the trans shifter and while holding the transfer case shifter I can feel the clicking more pronounced. The interlock solenoid alongside the trans shifter only clicks when I depress the brake pedal to release it out of park. It does not click at all once in r,n,d,1,2,3. I don't get a code just the flashing M&S lights. As soon as I shift into N it starts clicking immediately then M&S lights blink. I'm totally confused. I'm also wondering if the transfer case switch is making the noise?
Old Dec 27, 2022 | 07:24 PM
zski128's Avatar
In the 03 and 04 models neutral lockout solenoid is in the shifter rather than in the transfer case in previous models. I don’t know why that would be clicking, never heard of that problem. Do you have a scanner that can read the transmission codes? A consumer grade scanner generally can read them. If the M&S lights are flashing then you definitely have a code.
Old Dec 28, 2022 | 05:37 AM
betzdII's Avatar
I get no codes, but when I clear the no codes listed it clears the M&S (if that makes sense). or Turn the key off and on clears the M&S also. All I know is when I move the selector to N it clicks and the M&S lights start blinking.
Bub
Old Dec 28, 2022 | 03:57 PM
XRAD's Avatar
Did you replace the XYZ switch with new or used? You can remove the center console and check the diff locking solenoid for the the 'click...at least then you can tell if that is the noise source and work from there....
might be a faulty xyz....
