04 slipped liner?
Old Oct 2, 2014 | 10:06 AM
  #21
RicketyTick's Avatar
Originally Posted by Sarge103
I figured this was causing my misfires.
could be but you could take out those plugs and look in with a flashlight for a steam cleaned piston.
Old Oct 2, 2014 | 10:07 AM
  #22
Sarge103's Avatar
I'll do that
Old Oct 2, 2014 | 10:16 AM
  #23
I'll do that
Are you loosing coolant?
On a good note, since cylinders 4 and 5 are on opposite sides of the engine, your misfire codes may not be wet cylinder related and may in fact be your old wires but, look at the pistons anyway..especially if you are loosing coolant.
Old Oct 2, 2014 | 10:48 AM
  #24
Sarge103's Avatar
If I am it's happening very slow and Def none out the exhaust pipe.
Old Oct 2, 2014 | 11:13 AM
  #25
well that's good news. if you are not loosing enough out of your tank to notice and no steam from your exhaust then unlikely your block is cracked.
let us know what your pistons look like on those cylinders and how the hose test goes when you get a chance to do all of that.
Old Oct 2, 2014 | 11:16 AM
  #26
Sarge103's Avatar
going to try and set up some time to do it this weekend key word being "try". I will get back to you with results.
Old Oct 2, 2014 | 11:28 AM
  #27
good luck! I've got my fingers crossed for you.
just to be clear, you can have a liner slipping and ticking and not have a cracked block so once you determine if you do or do not have a slipping liner... then you can go from there.
and you do need new wires but, you may want to wait till you check your pistons and do your hose test and then come back to that.
Old Oct 2, 2014 | 11:36 AM
  #28
Sarge103's Avatar
yeah im going to take my time with it and do it right its not my dd i only need it for the occasional snow storm and off roading fun. So ive got nothing but time to get this thing in tip top shape.
Old Oct 6, 2014 | 04:05 PM
  #29
Sarge103's Avatar
Ok I did a little investigating pulled the 1,3,5,7 plugs since that's all I had time for and pulled the codes with my scanner. I also found that my coolant level did drop. Codes pulled:
P0135
P1590
P0155
P0171
P1300
P0301
P0303
P0305
P1319
P1668
Attached Thumbnails 04 slipped liner?-plug-1.jpg   04 slipped liner?-plug-3.jpg   04 slipped liner?-5.jpg   04 slipped liner?-20141006_162931.jpg
Old Oct 6, 2014 | 04:49 PM
  #30
RoverMasterTech's Avatar
Did you spray the bottom of the block to see if the clanging went away? The missfires and stuff are easy to fix, but it may not be worth it if you have a loose sleeve.
