1 5/8 inch lift ?
Where are you looking at getting a 1 5/8" lift? That's a rather odd size. Your best bets are either Rovertym, or OME. I'd go with RTE and you'll need a 3" lift to run 33" tires. In fact I don't know if the HD OME's would yield enough lift for the tires you want to run.
Rovertym and OME 2" lifts are very comparable in price and quality. Either one is a good choice. The Super Gaz 1-5/8" lift is a good lift according to the guys at AB but not nearly as popular here in the states. Rovertym also makes a 3" and 5" lift for the Disco but once you get to a 3" lift you have to start changing more than just the suspension components. A 3" lift would be the minimum required to run a 285/75 tire and would probably require a different offset wheel than stock to keep the tries from rubbing.
