1 vs 2 row Radiator
Old Oct 11, 2015 | 07:57 PM
roverwoody's Avatar
Default 1 vs 2 row Radiator
I read where 1 row radiators cools better than 2 rows in some cases. I know the D2 ome is 1 row. A lot of aftermarket is 2 rows. I notice that I been running hot with the 2 row. I'm switching back to an 1 row to see if my D2 can keep its temps down. Which is better for the D2?
Old Oct 11, 2015 | 08:17 PM
RoverMasterTech's Avatar
The radiator has never been a problem for the D2 1/2/3/10 row or whatever. The problem is the thermostat setup and the airflow through the radiator. The fix is Hayden severe duty fan clutch, new fan and inline thermostat.
Old Oct 11, 2015 | 10:12 PM
Joemamma1954's Avatar
Are you running the stock thermostat? I would rather have the 2-row radiator, and hd fan clutch. Mine was running consistent 210-220* and replaced the thermostat with the 180* and now run consistent 189-196*. My next purchase will be the hd fan clutch or electric fan mod. Also make sure the system has no air in it.
Old Oct 13, 2015 | 08:25 AM
drowssap's Avatar
stock radiator is a two row core
Old Oct 13, 2015 | 09:48 AM
Externet's Avatar
The number of rows has no relation to the cooling capability of a radiator.
A one row can have wider, thicker or longer tubes than a four row with narrower, thinner and shorter tubes.
It is about the mass of coolant held in its core that influences its performance.
Tubes spacing and number of fins also influence performance.
Stock radiators have 1mm thin tube gaps; provide short heat travel and intimate heat transfer but prone to clog with coolant deposits.
Old Oct 14, 2015 | 11:58 AM
NVDiscovery's Avatar
Would you elaborate on what you mean by in line T stat and HD fan and clutch? Are these direct replacements for the oem parts. Living in Las Vegas, NV I'm always looking for a way to keep my D2 engine cool. Thank you.
Old Oct 16, 2015 | 11:27 PM
roverwoody's Avatar
In line T state is a inline thermostat mod that some of us D2 owners have done. Heavy Duty (HD) Fan clutch. However, I'm thinking that a 2 row radiator might not best for our rigs. Stock is a 1 row.
Old Oct 17, 2015 | 12:23 AM
drowssap says 2 core
roverwoody says 1 core
Who is correct?
Old Oct 17, 2015 | 09:12 PM
Ok so what are the part #'s for the in line T stat and HD fan clutch? Thank you.
Old Oct 17, 2015 | 10:31 PM
https://landroverforums.com/forum/di...tat-mod-32216/
read down the post for pics and parts.
