1171 and 1174 Codes, Manifold Brake servo leaking?
Old Aug 4, 2014 | 10:23 PM
lrsmith62's Avatar
yea...was reading about MAFs tonight. Looks to me like Cardone is an aftermarket and most people are insisting on a Bosch replacement. I found a Bosch for $100 on Amazon, but they are usually near $200 whereas the aftermarket OEM ones (Cardone, etc... are 100-140. The one I got was $120 but I remember it wasn't in a Bosch box (yellow with bosch and/or land rover emblems on it). May try the Bosch MAF and see if I can return the one I purchased at O' Reilly.
Old Aug 5, 2014 | 07:06 AM
Jared9220's Avatar
That link to partsgeek I posted above has one bosch MAF for $122 and another bosch for $101. I bought the one for $101 after another member sent me the link. Sure enough it came sealed up in a nice yellow bosch box. Best price around.
Did you you ever get a chance to try smoke testing with the MAF still on the intake tube?
Old Aug 5, 2014 | 10:18 PM
lrsmith62's Avatar
yes....same results. Have a Bosch unit on the way. Hoping O'reilly's will take the other back. I'm a good customer there, so I think they will. Also ordered a new gasket for the throttle body where I thought I might have seen a touch of smoke. Will keep you updated as I try both these fixes.
Old Aug 10, 2014 | 08:31 PM
lrsmith62's Avatar
UPDATE.....well, switched out the MAF for a Bosch. No codes so far. I'm assuming the aftermarket MAF was the issue. Will update again if this changes but will call this case closed otherwise. Thanks for the help!
G,Demro
Jan 20, 2012 09:06 PM
xtina01
Dec 18, 2011 09:00 AM
BIG g
Jul 26, 2010 04:43 PM
DEEBEE060
Aug 19, 2009 04:39 PM
dewhorse
Oct 29, 2008 01:00 PM
