Codes 1171 and 1174
Old Oct 28, 2008 | 07:24 PM
dewhorse's Avatar
Default Codes 1171 and 1174
I just got these 2 codes in the last 4 days 1171 and 1174, I cleared them tonight and will see if they come back but from what I am reading they point to the O2 sensors. I just replaced the O2 sensors roughly 3000 miles ago. I just had my massive oil leak fixed and right after my mechanic said one of the pully bearings is bad.
I guess the good point is that it is no longer leaking oil
Also I recently got Bilstien's put on (got them for less than OME!!!) and she is riding a bit rough it seems.......
Any ideas
Old Oct 28, 2008 | 07:32 PM
Default RE: Codes 1171 and 1174
See if those codes come back, if they do double check your connections for the O2's.
If the connections are good then you probally just need a tune up.
It is probally riding rough because the shocks are new and still pretty stiff. They aill loosen up alittle with age.
Old Oct 28, 2008 | 07:36 PM
redhotbuzz's Avatar
these guys are gonna want more info.. year. make. what kind of oil leak.. what kind of bilsteins HD?
Old Oct 28, 2008 | 07:49 PM
dewhorse's Avatar
Sorry (glad Mike didn't chime in yet ) she's a '03 disco II with 110,000 got the O2's from British Atlantic. Replaced the rear intake gasket and the valve cover gaskets and one other I can't remember right now and the manifold gaskets (had and exhaust leak as well) had a tune up about 20-30,000 miles ago and replaced the plugs less than 6000 ago.
And if anyone wants a lead on a great deal for the shocks (no connection to company) let me know
Old Oct 28, 2008 | 07:55 PM
dewhorse's Avatar
The shocks are standard Bilsteins, at least according to them website.
Old Oct 28, 2008 | 09:14 PM
jmrivera's Avatar
sent you a PM...
Jonathan
Old Oct 29, 2008 | 07:16 AM
Mike is chiming in now.
Those codes can be from either a vacuum leak or a MAF, I doubt your 02's have caused this or you would hav fault codes showing a problem with them. By the way, the Bilstein's won't cause this either.
Old Oct 29, 2008 | 10:21 AM
dewhorse's Avatar
Thanks Mike, I will check it out for leaks
Old Oct 29, 2008 | 01:00 PM
Switzer's Avatar
ORIGINAL: Disco Mike
I replaced my front 02 sensors (the rear are OEM) and am now getting 1171 and 1174. The idle is slightly rough and 1171 comes up every other trip. I ordered new rear sensors. Is it reasonable to believe not replacing the rear sensors along with the front would cause this?
Cheers,
Pete
lrsmith62
Aug 10, 2014 08:31 PM
G,Demro
Jan 20, 2012 09:06 PM
xtina01
Dec 18, 2011 09:00 AM
BIG g
Jul 26, 2010 04:43 PM
DEEBEE060
Aug 19, 2009 04:39 PM
