12 mpg hwy!?
Old Apr 29, 2014 | 10:44 AM
jamestfl's Avatar
Default 12 mpg hwy!?
okay, I wasn't expecting great gas mileage, but that sounds awful low. took our first road trip in the Disco this wknd, about 600 miles r/t, at 70-80, and was getting about 12-13 mpg. does that sound low?
Old Apr 29, 2014 | 11:14 AM
dusty1's Avatar
sounds like you are bragging.
Old Apr 29, 2014 | 11:16 AM
Andy2Rover's Avatar
That's what I get on the hwy at same speeds. I have a 2000 Disco with 102k miles. Probably get 2-3 more mpg if you drive 55-60mph
Old Apr 29, 2014 | 11:18 AM
dusty1's Avatar
i was getting 15 and 1/2 stock. should have never checked it again. are you checking via math or? o2s swap can help, but it looks like you did that.
Old Apr 29, 2014 | 12:17 PM
mattmo78's Avatar
Sounds about right. I'm averaging anywhere from 11.5-12 in daily driving.
Old Apr 29, 2014 | 12:58 PM
acg's Avatar
acg
Same mileage as my Disco with a roof rack. It is about 13 to 13.5 without rack.
Old Apr 29, 2014 | 01:13 PM
FlyingZebra34's Avatar
Uh I just drove from San Diego to Fort Collins a few weeks ago. I averaged about 17-18mpg with the truck filled to the brim with tools, camping gear, and other useless crap I should've left at home.
My truck is lifted with over sized tires but (when it was running) it ran pretty smooth. I don't normally push the rpm's over 2k unless I'm hill climbing (screw that pass that goes through Vail)
If you go through DiscoMikes list and change out all the fluids, spark plugs and what not these trucks do ok.
Edit : also I check my mileage by topping up, setting the trip then when I top up again I divide number of miles driven by how much gas I need to fill up again.
Old Apr 29, 2014 | 01:16 PM
jamestfl's Avatar
ok, so it sounds like we're in the right ballpark. that's the UG reading, verified with basic math skills and some sobbing at the frequent gas station stops. We were driving I-95 and the Turnpike in FL, and you can't drive less than 70 without causing a wreck. Checked the difference in mpg b/t 70 and 80 and it was miniscule, so we ran at 80, hot as ***** out there too.
let me hijack my own thread... lots of wind noise up at 70-80, especially the front drivers A pillar and the rear pass door/window. any common issues relating to these? checked the seals, all seem good. maybe the finisher pieces not on properly?
Old Apr 29, 2014 | 01:29 PM
dusty1's Avatar
mine was the door seals. I took them all off, conditioned/washed and put them back on. it got rid of most of the noise.still get ,an every once in a while, noise from a gust, here and there. they looked fine, too.
Old Apr 29, 2014 | 01:33 PM
I get worried when these things don't make noises. Catastrophic failure is immanent.
