16mm head gasket
i think the head stretch bolts themselves are being referenced in this case. They appear to be about 16mm in size to me.
Yep, those are the head bolts. STOP WHERE YOU ARE, and don't try turning the ones you have exposed until you have removed everything under the rocker covers and everything down to the lower plenum as well.
The head bolts need to be removed carefully, in sequence, turning just a few degrees at a time especially when you are initially trying to crack them loose.
The RAVE explains all of this.
