180 degree thermostat question.
I got my coolant housing and hoses replaced about a month ago + a flush. All new fluid is in there. However I'm looking to put in a 180 degree thermostat this week. Do I still have to drain the bottom hose out too while I do this too?
Similar to this video; he explains he didn't drain the bottom hose because it already has new coolant in it.
I second this. Mines installed and I'm VERY happy. Also if the thermostat fails on a trip every parts store on this continent will have a thermostat for you on the shelf.
H Hill (04-20-2021)
Originally Posted by Externet
Draining does not imply discarding the coolant, if that is what you mean. Just collect and reuse.
I’m in the PNW, so comparably mild temperatures but I would say it takes no longer than 5 additional minutes to get up to full temp. Totally worth it (in my opinion) for more stable temps.
B Strife (04-20-2021)
Living in central Indiana and temps summer/winter can be anything, usually ridiculous! Lost 1 engine to an overheat, on this new one, I installed Extinct’s thermostat mod.
I’ll let you know about warmup, but if it takes a bit longer, no worries. Better than an overheat problem. Plus I have a block heater so when it’s really frigid, I’ll plug it in.
The following 2 users liked this post by H Hill:
B Strife (04-20-2021),
Richard Gallant (04-20-2021)
TRIARII
04-14-2014 11:46 AM
