had bad rain last night and found to bad leaks in rear, driping down both sides on to rear shelf brackets, could it be coming through top 1/4 windows? if so how to fix
The alpine windows are prone to leak, if they are leaking, the windows should be popped out cause you may also have a bad case of rust buyilding up around the seal.
Mike
