WATER WATER EVERYWHERE
Old Jun 8, 2008 | 06:21 PM
QUINCYSDISCOVERY3's Avatar
Default WATER WATER EVERYWHERE
I own a 2003 LR Discovery S. Water is dribbling down from under the dash area and collecting on the floor carpet and mat. It's a lot of water to be sure and I wonder if a drain line is plugged or something. Any ideas. Only does this when using the A/C. It is running down the side of the tranny hump or center console hump nearest the front passenger's left leg.
Old Jun 8, 2008 | 06:43 PM
roverguy7's Avatar
Default RE: WATER WATER EVERYWHERE
you ac drain lines are plugged. you can go under the car and unclog them, little rubber **** that come out on either side of the trans, shove a screw driver in there and move it around... youll get a shower doing this if youre not careful
Old Jun 8, 2008 | 06:50 PM
Clear the 2 drain tubes and then work on drying out your carpet before it gets moldy.
Oasisplayer311
Jul 6, 2015 06:28 PM
hh65flyer
Dec 10, 2011 09:50 PM
Shane83
May 5, 2011 07:48 PM
marlymarl
Apr 12, 2010 02:00 PM
Gordon Bombay
Dec 22, 2009 10:31 AM
