1996 disco won't start
Old Feb 6, 2010 | 03:54 PM
jbriggs's Avatar
Default 1996 disco won't start
It turns over but wont start. No spark to plugs, all the fuses are good. I tried 2 different scan tools/autotap and it can't find vehicle. Is this the ECM/computer?
Old Feb 6, 2010 | 04:20 PM
ptschram's Avatar
Check your fuses first.
Old Feb 8, 2010 | 10:40 AM
jbriggs's Avatar
All the fuses are good. That was the first thing I checked. Ignition switch is good. The scan tools don't see the vehicle. so I'm incline to think the ECM is the problem.
Old Feb 8, 2010 | 10:41 AM
okdiscoguy's Avatar
It won't. You have to get a rover compatible scanner to read the ECM.
Old Feb 8, 2010 | 10:44 AM
jbriggs's Avatar
The one I have has always worked fine and the one my friend has also has worked on this vehicle in the past.
Old Feb 8, 2010 | 10:46 AM
okdiscoguy's Avatar
Then I would lean towards yes. You will need a rover scanner to install the new ECU though. They are not plug and play.
Old Feb 8, 2010 | 10:49 AM
jbriggs's Avatar
The Disco manual says they aren't repairable but it doesn't say anything about programming. Thanks.
Old Feb 8, 2010 | 11:00 AM
okdiscoguy's Avatar
They have to learn the sensors and can only be open with a scanner. Just like if you replace the TPS or IACV, you will need a scanner in most cases. It may fire, but it will run weird.
Old Feb 8, 2010 | 11:02 AM
jbriggs's Avatar
Thanks. Its worth a try if I can find one without paying an arm and a leg.
Old Feb 8, 2010 | 09:01 PM
lst1187's Avatar
I went through this recently and for me, the fuses were fine and it turned over but did not fire. Listen for the fuel pump circulation. If you do not here a hum or buzz from the fuel pump that may be the issue.
Also had a short once. The fuse kept blowing due to the short. I found a bare O2 sensor wire that was causing the problem.
Hope this helps and good luck.
