1996 Discovery Dome light not coming ON when opening doors
Old Jan 18, 2009 | 08:11 PM
dieselgeek's Avatar
Default 1996 Discovery Dome light not coming ON when opening doors
Hello all,
When I turn the dome switch to ON, the light is ON and bright. However, then putting the switch in the middle, not ON, not OFF position. The dome light does not come on whenanydoorsare opened.
Any ideas?
Another gremlin to work out.
Old Jan 18, 2009 | 08:44 PM
Default RE: 1996 Discovery Dome light not coming ON when opening doors
The button on your door jamb is sticking.
Lube it.
Old Aug 9, 2009 | 01:00 AM
josemex's Avatar
I just finished painting my headliner and it looks amazing , now my front dome light wont turn on when I put it in the middle, it will if I move it to the On position , all the other lights work with the doors just fine the rear and the cargo one I'm just having this problem with the front one, Any Ideas ?? I checked all the fuses an all of them seem fine??
Old Aug 10, 2009 | 04:08 PM
SurfRat's Avatar
You painted your headliner????
Your front dome lamp has two hot leads. One wire is a smaller diameter than the other. Why who knows? One is hot for all on. The other is on the dimmer circuit.
The switch is a simple mechanical switch... pull it and check if one of the wires was in advertantly removed on re-install of the overhead fascia. Or may be it snapped off. 12 - 14 year old wires can get brittle.
Old Aug 19, 2009 | 02:20 PM
james2009's Avatar
8th Gear
I am having the same problem with my dome lights and will look this over. Thanks for the info.
My headliner is sagging. Do you happen to have any pics of the painted headliner and how tough was it to do?
Thanks.
Old Aug 19, 2009 | 02:36 PM
98roverguy's Avatar
Yeah I'd like to see pics of a "painted" headliner as well...
Old Aug 19, 2009 | 03:53 PM
hazletbassist89's Avatar
couple of other guys on the forum did it too, it looks pretty good. I'll be doing mine in a few weeks.
Old Aug 20, 2009 | 08:38 AM
camaroz1985's Avatar
I found pictures doing a search. I will be doing mine like this too. Looks very nice.
My lights are also not coming on when I open the driver's door, but all the others work fine. I will try to lube the switch, but because it is only one, I would think it could also be the switch.
Old Oct 4, 2009 | 06:34 PM
james2009's Avatar
8th Gear
Do you happen to know a website, or do you happen to have something that has step by step instructions on how to paint the headliner? Does it need to come out to be painted?
Old Oct 4, 2009 | 09:33 PM
lipadj46's Avatar
Yes, you need to remove the cloth clean off the glue prep the surface and paint it.
