1997 Disco I Rear Window problem
Old Oct 6, 2008 | 12:10 AM
felipenaves's Avatar
Default 1997 Disco I Rear Window problem
Hi all I own a 1997 Discovery SE7, my both rear windows stopworking, I check the fuses there are ok, the main console looks fine, I change the switchs from the console to the front windows and they work perfect. The both rear window just stop working, before there use to work with some problems, veryirregular.
Can somebody please give a tip what I can do there are half way down, thanks.
Old Oct 6, 2008 | 07:53 AM
Default RE: 1997 Disco I Rear Window problem
Sounds like the circuit board that controls the windows is cracked. Common problem, the solder joints get old and brittle and then crack and then with no connection the windoes wont work.
Pretty easy DIY fix.
I believe that the window circuit board is behind the glove box, but after you find it and remove it just re=solder the broken joints and replace the board and you are good to go.
Otherwise you can look for a used board on e-bay or your junk yard.
Old Oct 6, 2008 | 08:26 AM
Thanks Spike555 I will look for the circuit board, I have to take out the globe box to get to the board? I apreciate your help, regards.
Old Oct 6, 2008 | 10:00 AM
Yes, remove the glove box and the circuit board should be right there.
Old Oct 6, 2008 | 09:29 PM
XCELLER8's Avatar
hello !!I had the same prob with my '98..........atlanticbritish has a " window lift ecu repair kit", i believe it sells for about $17. you get a piece of wire & 2 connectors and about 5 pages of instruction on how to bypass the ecu !!!
works great.....only took a few minutes
check it out[8D]
Old Oct 6, 2008 | 10:03 PM
http://www.roverparts.com/Parts/AMR1282RK.cfm
Old Dec 25, 2008 | 03:51 PM
Thanks guys for the tip.
Felipe
twoxred
Oct 4, 2021 07:07 AM
Kcid1101
Jan 30, 2013 04:46 PM
dynomite
Oct 12, 2010 09:00 PM
fsc
Freelander
Oct 28, 2006 05:09 PM
jwandhistools
Jul 22, 2006 01:34 AM
