1998 Discovery Power Seats and Radio
Old Dec 16, 2009 | 09:42 AM
umoms's Avatar
Default 1998 Discovery Power Seats and Radio
On my 98 Disco both the passenger and driver side seats arent working. I couldn't locate a fuse for it but I noticed a bunch of relays under neath driver side seat. Could one of them control the power seats. If so, which one?
Also my radio is not turning on at all. I do even see the clock displaying on it. Is there a fuse behind the radio? Because I checked the fuse under the dash and that was fine.
Old Dec 16, 2009 | 11:13 AM
Rover Chris's Avatar
I would check fuse 3 (60A) in the engine compartment and fuse 6 under the drivers dash. not sure on your 98 but on my 97 it looks as though the two seats are powered independently, the passenger seat is fused through the ignition switch so the ignition must be on but the drivers seat is wired through the ignition switch and the drivers door trigger allowing this to be operated with the ignition off and the drivers door open. It may be worth it to check all fuses (don't need to check airbag fuses). my schematics show the passenger seat and the radio share the same fuse (20A fuse 6 under dash)
goatman
Jan 12, 2013 10:08 AM
gulfcoastgorilla
Apr 20, 2012 06:13 PM
booper169
Nov 9, 2010 09:10 AM
1994discovery
Jan 30, 2008 03:19 PM
gsxrgessler
Jan 26, 2008 08:34 PM
