1st off-road excursion - success with a twist
Old Sep 12, 2021 | 12:25 PM
zacharyz28's Avatar
Has any one installed actual heat extraction vents in their hood?
Old Sep 12, 2021 | 04:37 PM
dswilly's Avatar
Yes, that has been done, not sure if it helps but probably does. I would think water ingress could be your next problem with a louvered hood. I don't think the engines radiant heat and engine compartment heat influence the operating temperature if your cooling system is working right. At least in my experience it does not. If these were air-cooled VW's then yes. My only concern is the wear on underhood accessories and components. Even with that I don't think it is as bad as it appears. Humans have crappy heat tolerance. 150-200 deg to us feels crazy hot but is not hot in the world of properly engineered plastic, metal, and machinery.
I have wondered if the lower engine tray cover has influence on airflow. Mine is removed at the moment but maybe tt funnels the air better out vs just causing a low pressure effect off the fan. Sort of an extension of the fan shroud.
Old Sep 12, 2021 | 05:51 PM
Extinct's Avatar
Originally Posted by dswilly
Curious if this funnels engine compartment air into the interior vents? I assumed that seal was to prevent that as the interior vent is on the other side. Depending how clean and tight everything is in the engine bay that air could be pretty nasty beyond hot.
The seals are for LR's convoluted cabin air filter system. The idea was pull outside air from the base of the windshield through the filter and in to the cabin air intake. The rear most seal is so air does not bypass the filter, the front seal is so the cabin air does not pull in engine air heat. I pull them both and keep my AC on recirc. The recirc setting pulls air only from the interior, and pulling both seals allows the hot underhood air to escape at low speeds, at high speeds the high pressure zone at the base of the windshield pushes cool air down in to the engine compartment. In both situations the engine compartment is cooler.
Old Sep 13, 2021 | 07:48 AM
Daytoman's Avatar
Right on about using recirc. This avoids any issue with drawing in the extra heat. I only use recirc anyway, it’s better performance from the AC regardless IMO.
Zelatore
Aug 24, 2018 07:51 PM
adamwest21
Dec 21, 2015 12:32 PM
jimvw57
May 18, 2015 03:33 AM
Jantiz
Oct 3, 2007 02:07 PM
fx300
Sep 15, 2007 05:55 AM
