1st Post >>> Door Lock Disco II Problems
Old Oct 5, 2014 | 05:48 PM
TJ Ranfranz's Avatar
4wd High
Unhappy 1st Post >>> Door Lock Disco II Problems
I've read many posts trying to figure this out. I've had my 02 Land Rover Discovery II for two years. The other day the key fob and the manual door lock and unlock switch near the radio all quit working - the only way I could get in was with the key manually thru the drivers door - I was able to use the interior handles to unlock the other doors from the inside but today that stopped working also so I can only use the drivers door which really sucks! alarm works, key only locks and unlocks driver door. is there a quick fix?
Old Oct 5, 2014 | 07:29 PM
stb616's Avatar
Check the fuses
Old Oct 5, 2014 | 09:11 PM
4wd High
I checked the fuses under the steering column - they are good
Old Oct 6, 2014 | 12:01 AM
jfall's Avatar
Replace the lock motor mechanism on the driver's door.
If these fail and jam where as the contacts in the unit are telling the central locking
somthing which is untrue, then nothing works anymore.
Old Oct 6, 2014 | 11:16 AM
4wd High
thanks! and ideas on good places to get parts?
Old Oct 6, 2014 | 11:21 AM
drowssap's Avatar
paulgrant@mac.com
Old Oct 6, 2014 | 12:19 PM
OCMike's Avatar
Could also be the Keyless alarm module that is located in the ceiling, just in front of the rear sunroof. I replaced mine, and my keyless entry now works on all doors except for the drivers side. Need to replace the lock motor mechanism next.
Old Oct 15, 2014 | 10:48 AM
2004DISCO's Avatar
When you say "lock door mechanisam" Do you mean the actuator or something else? My driver side lock does not want to unlock but it does lock on 2nd try, this just started happening. Not sure what is wrong with it.
Any ideas?
Land Rover Actuator, Left Front Door (Genuine Part # FQJ102910) | Land Rover Electrical Parts
Old Oct 16, 2014 | 08:57 AM
OCMike's Avatar
Any ideas?
Yeah. That's what I meant.
Old Oct 17, 2014 | 09:16 AM
2004DISCO's Avatar
OK Cool... Another thing to fix I guess. BUMMER
