2 Questions
Old Dec 17, 2007 | 01:26 PM
humroot's Avatar
Default 2 Questions
Hi everyone. I have 2 quick questions.
1. I had my mechanic change my plug wiresto Magnecor, which I supplied to him. But they fit pretty tight...there is hardly any play and one is literally pulled tight across the valve cover. Is this how they should fit?
2. Can I replace the u-joints myself or is it a royal pia?
Thanks!
Jamie
Old Dec 17, 2007 | 01:47 PM
98roverguy's Avatar
Default RE: 2 Questions
1. I'd take a close look at the wires. He may not have installed the correct ones to the respective cylinder. See if some of the wires have a lotof slack.
2. Removing the driveshaft is a fairly easy task, but you'll need a press to remove the u-joints. I suggest you remove the driveshaft, purchase your u-joints and take them to a machine shop. It will be muchless then taking the whole task to the dealership.
Old Dec 17, 2007 | 02:09 PM
Find a drive line shop or a tranny shop and have them replace the u-joints, you don't want to tackle them on your own.
Old Dec 17, 2007 | 02:51 PM
okdiscoguy's Avatar
The U-joints that are the bear are the ones in the double cardan joint. The centering ball is tough if you haven't done one. I agree with the previous posts, take it in and let them do it. Might not be that much more to let them pull the shaft as well....
Old Dec 17, 2007 | 05:36 PM
willstevens's Avatar
I had the same issue with my wires. All are connected correctly and there is very little slack. Had to modify some routing. As to the shafts, had a driveline shop do mine, dropped them off, new joints, centering ball kit and nipples in the shafts, greased out the doorfor $216.00.
Old Dec 17, 2007 | 06:16 PM
jkid's Avatar
They do fit pretty tight against the valve covers. They should all be clipped into the wirelooms so that they aren't actually touching the covers though.
If you've never done u-joints, don't bother.If you're looking for areal challenge and have the time, then yes you can. Then thesecond time you need to doit, itwon't be a royal pia.
Old Dec 17, 2007 | 07:34 PM
ajh's Avatar
ajh
The neapco u-joints are out of stock at the one place I found everything, any other suggestions on where to find them.. it's was something lame like Parts America I had tried to order from, their shipping costs were insane. 2 day shipping within the USA on less than 15lbs for $75 or so....
Old Dec 17, 2007 | 07:57 PM
that is crazy. Can you buy online? Have them shipped to your door for cheaper than that. I have neapco and 1 spicer in mine.
Old Dec 17, 2007 | 08:08 PM
Fonzie's Avatar
I really hope that's not how they fit! I just purchased a set from Disco Mike's friend Tony at Cerrones in Redwood City CA. The label on the box did not list "Discovery", only "Range Rover". But he assured me that the #80242 was the correct set. Can anyone else here verify that part#?
My local dealer is installing them tomorrow morning and if the tech thinks they're too tight I'm gonna end up having them install the crappy stock leads [>:]
Old Dec 18, 2007 | 06:39 AM
jkid's Avatar
80242 looks right, though I'm not 100%.
Any good parts store should have the joints, I wouldn't pay for shipping.Ipicked up3 neapco's anda spicer centering joint for about $75 at advance auto parts (which is basically parts america - they've changed names a lot). Napa also had them.
