2" rte
2" rte
i am new to this. ive been lifting mostly jeeps my whole life. i cant seem to find information on what im planning to do... im getting new 2" rte springs. i need to know what else i would need. its mostly going to be for looks. and can i use the oem 18" wheels? and what is the biggest tire i can run? do brake lines need to be adjusted?
You will need a new OME steering stabilizer. Which RTE springs did you order? The type of wheeling you plan to do will determine the wheels to use. Most people that play medium to hard always use 16" wheels for better tire designs, stronger side wall and less expensive tire along with the fact 16" tire will hold up much better off road and not tear out sidewalls as easily.
http://www.rovertym.com/suspensionkit.htm
ideally this a list of stuff you should get. weather you get it all from them or part the stuff together.
