2000 D2 - every gear is like neutral except P. Does not Go! Help needed.
Ok harder then it sounds. Difficult to get to and in not sure how to disconnect them. I am capable so don't worry but I need some direction. In a union sheetmetel worker.. Lol (don't worry, in a limo driver). Looks like two lines on passenger side which someone has marked with a light green paint marker and. One on the driver side. The two that appear to be coming from the tranny are the one drivers side and the lower passenger side. it has the larger battle tray for two batteries. Doing my research now. Any help is appreciated. Thanks
Ok. After further investigating, I found that the lower cooler line is the return and the upper is the supply to the cooler. This told me to follow the supply line which took me to the drivers side lower one on the cooler. I figured out how the quick release works, actually pretty easy after some wd40. Unhooked it, put a PC of clear condensate line in the end and ran it down to a bucket. Started the truck and nothing! So fluid is not being moved to the cooler correct? Is there any other things I should be looking at before I assume the tranny pump is bad? Wiring, special hidden fuse, sensor etc...
- the plug with two small wires that appears to go to the bottom of the cooler was unplugged as well but probably has been for some time. What does that do?
