2000 D2 Factory Center Cup Holder Removal
Old Jan 22, 2018 | 04:31 PM
Lisa Bunch's Avatar
Default 2000 D2 Factory Center Cup Holder Removal
Well, this is embarassing.. I read the manual, removed ashtray & coin holders, removed 2 screws behind each, and can't see the other screws to remove the cupholder/ash/cpin tray assy.
Getting ready to install temp and oil press gauges in pod under where cup holder is now. Never use because in Arizona we buy large 44oz mega drinks with lots of ice. They don't fit.
Am I taking too much stuff off? Do I just need to yank on the handle and rip it out?
And to think I'm going to be doing my own head gaskets...sheesh!
Old Jan 22, 2018 | 04:43 PM
Best4x4's Avatar
Should be 3 screws per side, 2 are located further back. Then the entire assembly will basically fall out.
Old Jan 22, 2018 | 04:58 PM
Lisa Bunch's Avatar
Yep, found em way high in the corners. The screws were hard to remove, very picky about the bit style, and took a lot of torque. I will box my orig up and get one from a wrecking yard to cut up.
Old Jan 22, 2018 | 06:17 PM
Extinct's Avatar
Those are desirable for 03-04's which did not come with them.
Old Jan 22, 2018 | 06:23 PM
The Deputy's Avatar
Just be sure to check your knuckle clearance, while shifting hi-low lever...if you decide to mount guage set there. I usually hit the cup holder tray, while shifting to low...couldn't imagine anything larger in its place.
Brian.
Old Jan 22, 2018 | 07:10 PM
Davis31052's Avatar
I had to use two separate gauge mounts to do my set up.
The one plastic pod for two Autometer 2 5/16 inch gauges wont work with the hi-lo shifter.
Old Jan 22, 2018 | 07:17 PM
Best4x4's Avatar
Scangauge II fits under the 03-04 blank plate & I can shift without hitting it.
Old Jan 22, 2018 | 09:03 PM
Friday Night Disco's Avatar
Please do a write up and post pictures of what you are doing, I am interested in doing something similar
Old Jan 22, 2018 | 09:20 PM
Lisa Bunch's Avatar
Will post pics, because I bought a double dash pod which I am mounting upside-down where the cupholder went. Mechanical gauges mean a bigger hole through the firewall too.
Old Jan 23, 2018 | 12:35 PM
Lisa Bunch's Avatar
I have propped the gauges in position. The center console is being removed due to severe cracking from the Az summer heat. I'm going to have to figure out what to do about window and seat switches.
I have never shifted it into low. I don't think it has EVER been shifted into low. Kinda nervous to do it..does the engine need to be running?
That blue thing is propping it up.
