2000 Disco II: Transmission troubleshooting question
Ok...here goes. Back in December I was driving to work when I felt a small shake and then about 30 seconds later it felt like my transmission slipped into neutral. So I had it put on a trailer and delivered to my house. Fast forward to May 2011. I bought some things that I needed to put in my garage. Well, my Disco was parked about 1FT-2FT from garage door entrance, so I needed to move my Disco forward in the driveway. I went in the house to retrieve my key and make my way back out and start up my Disco. Started up I try to push the Rover forward while in PARK. Earlier I was able to move it while in PARK. No such luck. So I put it in DRIVE and give some gas and low-and-behold it drives forward. I stop and put it in REVERSE. She moves back. I did this a total of about 5 or 6 times.
So my question is this. It seems to me that the transmission is fine. Is there possibly some electrical wiring that goes to thee transmission that my have a short or loose connection?
Disco II's should have the transmission fluid and filter replaced every 60k miles. That means that your truck should have had this done twice already. It is very possible that the transmission in your truck has never been service, which is why you might be experiencing problems with it. Just because it is full of fluid doesn't mean that it is OK.
LR Disco II's should have the transmission fluid and filter replace every 60k miles. That means that your truck should have had this done twice already. It is very possible that it the transmission in your truck has never been service which is why you might be experiencing problems with it. Just because it is full of fluid doesn't mean that it is OK.
On another note I took it for a drive around the block a few times....no problems.
on
So Spike hit on the first issue, you are now low on fluid cause you didn't have the engine running when trying to check the fluid.
I would suggest you plan on 2 drain and refills, apx 12 quarts, plus a filter and a bottle of Lucas tranny stop leak.
When you are ready to do the service, send me your number so I can walk you thru what to do.
