2000 LR Discovery - tire recommendations & questions
Old Jan 23, 2025 | 02:48 PM
  #21
whowa004's Avatar
mine do that in one of mine in the winter, gets better as it warms up. Most likely dirty contacts in stalk if you search it's been answered, I haven't bothered to dig into it as I don't have many turns before car warms up lol
Old Jan 23, 2025 | 08:39 PM
  #22
ttr55's Avatar
Holy cow that thing is CLEAN! And one of my favorite colors. As others have said that could fetch big bucks on BaT, but if you are up for you should definitely keep it. Smooth roof is sweet, and with that low of miles it should be a dang reliable d2, especially if you use this forum to bullet proof it ahead of time.
Old Jan 24, 2025 | 08:19 AM
  #23
jimvw57's Avatar
After 35 years, the kids are much more expensive, and I earned every single grey hair!! And they are always your kids no matter how old they are....
Turn signals sounds like a corroded connection, you could check the one at the lower end of the steering column or connections at the relay blocks, but if it gets better, it might work OK after using it a bunch.
Old Jan 24, 2025 | 08:23 AM
  #24
PickleRick's Avatar
I used to have some finicky switches on my boat every spring when Id launch after a long winter layup. Even the tach would be bouncy.
A little electrical grease on the fuses, connectors and tach pickup and that issue has gone away.
Old Jan 30, 2025 | 08:30 AM
  #25
kmrgtr's Avatar
Thanks all for the advice on the switch - cleaned - greased it and it works now.
QQ - does the 2000 Disco - have a traction control off button?
Old Jan 30, 2025 | 08:40 AM
  #26
Diesel Gypsy's Avatar
[QUOTE=QQ - does the 2000 Disco - have a traction control off button?[/QUOTE]
Yes it does, it's called the "3 Amigos" lol But it's not a button, it's automatic!!!
Old Jan 30, 2025 | 09:45 AM
  #27
Harvlr's Avatar
No off button. And to your post from a few days ago, air suspension (rear only) was an available option, certainly not on all of them.
Old Jan 30, 2025 | 12:23 PM
  #28
Richard Gallant's Avatar
@kmrgtr No off button for traction control it is brake traction control, not engine based system there is never any need to turn it off
GavinC
Jun 9, 2026 04:56 PM
