2001 disco 2 vibration "front drive shaft"
Old 05-15-2014 | 03:15 PM
PanamaDisco's Avatar
Default 2001 disco 2 vibration "front drive shaft"
I have been noticing a vibration only on acceleration above 30mph it has been getting worse. Also in reverse there is a slight chirping sound . My drive shaft is still factory. Is there any way to determine if it is the drive shaft. Can II take it off and drive and see if it goes away. Also if I do need a drive shaft can I just buy a $300 of ebay. I drive mostly on the pavement. If off road usually sand or very well kept hunting roads.
Old 05-15-2014 | 03:26 PM
ralphobell's Avatar
If you have the CDL on your transfer case you can remove it and lock it and test. Most likely it is that our a bad tire balance. Some 2001 have the cdl and some don't. Won't know until you look.
Old 05-15-2014 | 05:24 PM
If it was tire balance when I let of of the throttle at 30-50mph it should still vibrate but as soon as I take my foot off the gas it stops.
Old 05-15-2014 | 05:33 PM
Dane!'s Avatar
Pull the driveshaft. If its still factory you need to replace it anyways. Its more than likely that.
Old 05-15-2014 | 07:26 PM
Well just showed it to my knowledgeable mechanic AKA father in law. Took him to seconds to tell me not to drive it home. The U/joints are shot. Going to rebuild this weekend.
Old 05-15-2014 | 07:30 PM
ralphobell's Avatar
I said it most likely was the drive shaft, the tire balance was another possible issue. And your dear old paw proved me right.
If you have the CDL you can remove the drive shaft lock the cdl and drive it home.
Old 05-15-2014 | 07:44 PM
I'll be fine. Ride home with wife. Drive her car tomorrow and come fix it this weekend. Also going to do the major service that was recommended. Thanks for the advice. I may turn on my radio soon and stop freaking out about every sound. Tires and wheels and lift ordered.
Old 05-15-2014 | 07:54 PM
Dane!'s Avatar
No, you should be aware of the sounds your truck makes. Ignorance isn't bliss with a Land Rover.
Old 05-15-2014 | 09:50 PM
dr. mordo's Avatar
You dodged a bullet - that chirp was a sign of imminent failure, and when the front shaft goes it often destroys the transmission.
Old 05-15-2014 | 10:04 PM
Grew up in a service department so I know if something sounds different get it checked out. Do any of yall know if a 33.9/11.6r20 will fit with the 3" terrafirma? I know it's not your style. It's a Florida thing. I have on order 33/10.9r20 but have to wait 3 to 5 weeks to get the wheels made with the correct offset to avoid having spacers and may call and go bigger. No serious off reading no rocks no hills it's florida.
Quick Reply: 2001 disco 2 vibration "front drive shaft"
