2001 disco 2 vibration "front drive shaft"
I have been noticing a vibration only on acceleration above 30mph it has been getting worse. Also in reverse there is a slight chirping sound . My drive shaft is still factory. Is there any way to determine if it is the drive shaft. Can II take it off and drive and see if it goes away. Also if I do need a drive shaft can I just buy a $300 of ebay. I drive mostly on the pavement. If off road usually sand or very well kept hunting roads.
If you have the CDL on your transfer case you can remove it and lock it and test. Most likely it is that our a bad tire balance. Some 2001 have the cdl and some don't. Won't know until you look.
If you have the CDL you can remove the drive shaft lock the cdl and drive it home.
I'll be fine. Ride home with wife. Drive her car tomorrow and come fix it this weekend. Also going to do the major service that was recommended. Thanks for the advice. I may turn on my radio soon and stop freaking out about every sound. Tires and wheels and lift ordered.
Grew up in a service department so I know if something sounds different get it checked out. Do any of yall know if a 33.9/11.6r20 will fit with the 3" terrafirma? I know it's not your style. It's a Florida thing. I have on order 33/10.9r20 but have to wait 3 to 5 weeks to get the wheels made with the correct offset to avoid having spacers and may call and go bigger. No serious off reading no rocks no hills it's florida.
