2001 Discovery 2 - Motor Issue
Old Jan 1, 2026 | 07:19 PM
JRN2024's Avatar
Arrow 2001 Discovery 2 - Motor Issue
I have a real nice Discovery 2 I have had for 7 years. I installed a lot of new parts valley gasket, new injectors, power packs water pump, power steering pump, sensors, it was running great for a while.
Took it out on a long ride and it started running in less than 8 cylinders, replaced all spark plugs and now it will not even start. When I try to get it started now, the engine seem to reach a point where it catches on something and slows the starting speed, no loud noises.
Where should start I got a lot of time and money invested on this D2 and like the vehicle but dont know if this is a major failure or not. Any suggestions?
i installed
Old Jan 2, 2026 | 06:23 AM
mackendw's Avatar
you say "started running on less than 8 cylinders".... how did you determine that? are you getting any codes being thrown?
Old Jan 2, 2026 | 09:52 PM
Harvlr's Avatar
My first guess is that you crossed some spark plug wires wgan replacing plugs.
Old Jan 4, 2026 | 08:23 PM
JRN2024's Avatar
It was running rough but I mover the cables around to where I believe it has the correct firing order but now ir won't even start. I have to buy a scanner have not checked for codes maybe I need to do that first.
Thanks
Old Jan 4, 2026 | 10:09 PM
Harvlr's Avatar
It's not easy to get at, but the spark plug numbers are written on the coil pack brackets.
Old Jan 6, 2026 | 12:45 PM
mollusc's Avatar
shadycake
Sep 13, 2021 09:04 AM
Elliemcqueen
Mar 22, 2016 10:15 PM
mquinn698
Dec 27, 2013 02:06 PM
Brad Luca Ciociola
Jan 27, 2012 08:49 PM
derek.saylor
Jan 30, 2011 12:50 AM
