2001 Discovery 2 transmission fluid additive?
Old 11-05-2019, 10:09 PM
DodyDisco's Avatar
Default 2001 Discovery 2 transmission fluid additive?
Going to change out the fluid on my disco tomorrow. I could swear I had read about a beneficial additive to toss in there while i was at it, but I'm not finding it again. Any tips on additives, if they prove beneficial I'd like to use one.
If not then less to buy at the store.
Thanks
Old 11-06-2019, 12:53 AM
Brandon318's Avatar
Don't add anything, just get a good quality ATF.
Old 11-07-2019, 12:25 AM
DodyDisco's Avatar
Well im all done with the fluid change. Only 4.75 ish quarts came out, pretty murky brown looking. . But the same amount went back in. Went through the gears. Went for a drive. Still held the same amount. Calling it good i suppose. Gonna change it out again in a few weeks to get more fresh fluid in.
Old 11-07-2019, 06:12 AM
mollusc's Avatar
Originally Posted by DodyDisco
Went through the gears. filled the transmission the rest of the way with the engine running. Went for a drive.
i fixed your post for you. cf. the rave manual for the correct fill procedure.
Old 11-07-2019, 06:16 AM
Jason Feuerstein's Avatar
I use Hydra Trans Tune. Seems to smooth out some of the rougher shifting.
JUKE179r (11-08-2019)
Old 11-07-2019, 12:15 PM
DodyDisco's Avatar
Damn. Thanks for pointing that out from the rave. I screwed that part up in my procedure. Not just a typo. My rave download isnt working and i went off a sticky guide. I must have missed to keep er runnin..Crap
Back out to check and fill one more time i suppose.
Thanks
Also found a new rave download thats working well.
Old 11-07-2019, 08:24 PM
DodyDisco's Avatar
So I did it per the rave exactly this time. Took about another quart. About 5.5 total.
Feel better about it now. Gonna try to do 2 more times over a few weeks to get more newer fluid it. No problems with the tranny. Hopefully none surface from changing fluids. My 2000 mercedes tranny took a dump after fluid change and was fine up untill it. And the damn stealership did that service
Old 11-08-2019, 12:08 AM
Richard Gallant's Avatar
Received 1,178 Likes on 815 Posts
@DodyDisco I had mine done 2 years ago, no problems at all.
Old 11-08-2019, 06:36 AM
mollusc's Avatar
did you change the filter as well?
Old 11-08-2019, 07:59 AM
MyLandLover's Avatar
7th Gear
I was getting some transmission "clunking" with standard transmission fluid, but I changed it to Mobil One Synthetic, and all the noise went away
Quick Reply: 2001 Discovery 2 transmission fluid additive?
