2001 LR DII A/C Clutch Relay Location
Old 07-10-2020 | 02:11 PM
tom03110's Avatar
Default 2001 LR DII A/C Clutch Relay Location
Can someone tell where the A/C Clutch relay is located? My A/C isn't blowing cold air. When I connect 12V directly from battery the clutch engages.
Old 07-10-2020 | 02:30 PM
boston4's Avatar
Welcome to the forum! Compressor clutch relay is R11 in the engine compartment.
I'd suggest troubleshooting in the following order:
1. Is there the correct amount of refrigerant in the system? There is a high/low pressure switch that will prevent the clutch from engaging if the refrigerant is too low (or too high - but that's probably not the case here).
2. If there is the correct amount of refrigerant, try bypassing the pressure switch - it plugs in near the receiver/dryer, which is behind the grill. Closed circuit = 12V to the compressor clutch via the relay.
Once those are working, then you just need the ECU to send a signal to the clutch, and the clutch to engage via the relay. I don't think issues with the relay are common. Usually there's a leak.
Old 07-21-2020 | 08:25 PM
dparham's Avatar
mine never disengages and disco starts to run warm and drain battery.. could that be the relay?
markdeg
11-28-2018 10:29 AM
CollieRover
07-24-2016 10:41 AM
acamato
12-23-2015 12:35 PM
diverjohn52
04-15-2011 12:29 PM
lugo35
Engine & Internal
12-13-2004 06:51 PM
Quick Reply: 2001 LR DII A/C Clutch Relay Location
