A/C compressor or clutch lifespan
Old Jul 24, 2016 | 08:36 AM
CollieRover's Avatar
Default A/C compressor or clutch lifespan
Hey guys,
Having an issue with intermittent A/C. I suspect a failing relay or a/c compressor clutch or compressor.
The original is in there, and I am just wondering if they have failed for people and at how many miles.
Old Jul 24, 2016 | 09:41 AM
disc oh no's Avatar
If it's intermittent, sometimes it's just wear on the clutch surface. There's a spec for the gap between the clutch plate and pulley. If it gets too far apart, it will start giving you trouble.
To test it, you can turn the ac on and if the clutch doesn't engage, you can tap the front of the clutch and see if it engages.
If that works, you can remove the center nut on the clutch and re-shim it. Sometimes there are more than one shim in there and you can remove one to put it back within spec. If not, you may need to get some thinner ones.
houm_wa
Apr 3, 2015 10:33 AM
04duxlr
Feb 3, 2014 12:56 PM
SDinDS
Jun 7, 2011 12:33 AM
darkaegis
Oct 19, 2010 05:45 PM
BURover
Feb 20, 2009 07:07 PM
