2002 Disco info
2002 Disco info
Just looking for a little information. Bought a 2002 discovery. I'm wondering if the axles come with a differential locker? if there is no locker are they limited slip? Who makes the axles for LR?
Does LR make a oem lift kit for the discovery? I have rear airbags and front coils, would like to lift it 2" maybe 3"
Does LR make a front bumper so I can mount a 9000lb winch?
Haha, just go to Rovers North, everything ur looking for is stock parts including the lift, you may need a bull bar or brush guard for the winch but you can find one used at roverland parts. and yes it is a dif lock, you should see that in the manual or the thing that looks like a small shifter should say it on it.
you can lift the airbags as well, and then it provides even a greater lift with the offroad switch. 2" lift + switch = 4" when offroad.
Why should the SLS be removed if you are installing lockers, there is not a bit of truth to that statement.
For a lift, use only Old Man Emu or RTE coils along with HD OME shocks.
There are many after market front/rear bumpers on the market, here again, OME and RTE or 2 of the more common ones on the market.
