2002 discovery stalls when coming to a stop
My wifes 2002 land rover discovery has the tendency to stall when it comes to a stop. Sometimes the idle will drop and come back without stalling, but generally it will completely stall. If we put the truck in neutral it won't stall or drop idle. It's been pretty well taken care of, reg oil changes and what not, 135,000 miles. No CEL to indicate a problem. I took it to a mechanic around here and they said they pulled an engine code that said "NA Permanent volt supply fault" and a few transmission codes that said "21 - can message MDIND invalid FTLMES" "25 - can message TANS invalid Ffh" and "20 - gear ratio monitor fourth gear". I'm lost and can't find much information about those trans codes. Any ideas?
