2002 that does not run very well at all and the key will not come out
Hello!
I just got a 2002 Discovery today and I am working the bugsout of it, It will start but will not rev and runs rough. At times it willstall out. I scanned it and had the following codes
P1536
P0650
P0560
P0335
The code that concerns me is the camshaft sensor code; theothers I am not sure are really big issues at the moment.
My battery was low, as this truck has sat for over a yearbefore I started working on it so that is why I think I had the system voltagecode.
What I have done is make sure I have spark and fuel and theyare ok, I also made sure all my grounds were clean and tight, I did find theone on the rear valve cover to body loose.
I am yet to find the cam position sensor and I would like toconfirm the wiring on it before I go and spend a fair amount of money on a newsensor. Another issue with this Rover is I cannot remove the key from theignition.
So my issues I need help on are the cam sensor location andwhat it takes to remove it, as well any other items that would cause it not torun as it should with the codes I have and what would cause the key to stay inno matter what I do?
Any and all info would be appreciated!
on
First thing you need to do is down load a free copy of the Rave Cd, shop manual, link is below.
Then go get your battery charged, codes indicate low voltage, then clear the codes and see what comes back.
1536 showing a/c out of range.
Once all this is done, then go to the top of this section and read/do my major service kist especially the front drive shaft.
How many miles on this truck?
Battery is good now and new. Codes erased and the camshaft sensor code comes back. Front drive shaft looks like its new or newer. The truck has 141k miles on it.
I did download the manual last night and it is very helpful so far. I wish I had a spare camshaft sensor to install to test before I buy a new one
