2003 4.6 oil sending unit thread size?
Old Feb 4, 2023 | 05:43 PM
Brinkley's Avatar
Default 2003 4.6 oil sending unit thread size?
Hi all I'm trying to connect a oil pressure gauge but the threaded adapter doesn't fit. Anyone know what size thread it is?
Old Feb 4, 2023 | 09:10 PM
zski128's Avatar
Old Feb 5, 2023 | 08:45 PM
Brinkley's Avatar
Thank you for the response. I finally found the fitting that threDED into sending unit after all weekend. I had an oil light come on and was trying to see if oil pump took a s@#$.
Had to rig up a gauge gauge cause nobody had a pressure tester. Ended up reading zero. I'll post size tmrw when I go out again. But thanks soo much for reply. I spent day in town buying any fitting that looked like it might fit.
Old Feb 7, 2023 | 09:14 PM
Discorama's Avatar
M20x1.5 (oil cooler port) or 1/4-20 UNF (next to the oil pressure switch).
Old Feb 8, 2023 | 06:22 AM
redwhitekat's Avatar
becarefull where you plug that in, if you plug it above the oil oem port there is a valve in there and it will give you a false reading on your oil pressure guage, it will start bouncing up and down
Old Feb 8, 2023 | 09:04 AM
Brinkley's Avatar
Thanks, I found a fitting at a parts store. I can't find a number on it to share. Pressure registered zero on the gauge. Gonna pull pump and check it.
I took all the bolts "I think" off the oil pan but that thing still feels bolted on. Got the 2 in the back that go into trans and the ones all around. I've pounded
with rubber mallet. Looks like aluminum kind of afraid, do you guys think a dead blow hammer would be to much?
Old Feb 8, 2023 | 09:50 AM
Harvlr's Avatar
In my experience usually when something feels like it’s still bolted on it is. I know there are a couple of oil pan bolts that aren’t obvious. Don’t hit too hard. You may need something like a putty knife between the pan and the block/timing cover to start breaking the gasket free. But be careful. As you noted, the engine is aluminum and will scratch quite easily.
Old Feb 8, 2023 | 10:04 AM
Brinkley's Avatar
Yeah my thought exactly. It is so solid that I feel like I must be missing something. I'll take a few pics and post them up here maybe someone will see what I've missed.
Old Feb 8, 2023 | 11:00 AM
whowa004's Avatar
Check the rave as you can count how many bolts there are and see if you have that many out already. Ran into a similar issue first time dropping the oil pan..
Old Feb 8, 2023 | 05:00 PM
Brinkley's Avatar
Got it there were the two that were recessed up into the pan. Now its the pumps turn I got them all out " I think". I pulled four on left side and two on right. I took off the water pump. I got it loose on bottom a bit but the top is still very solid. Going to dive back into it tonight.
